kennethwooster wrote:
I agree he should not be missing with your rig. I keep a back flush on mine and also have both houses hooked up. Its not a bad way to do it until someone misses with your system.Hopefully you can get it worked out without to much hassle.
Why would you want to have that black hose hooked up when not flushing :h Generally its a once a week affair dumping the black tank. I don't see any inconvenience to hook it up to flush.
It seems having that hose hooked up is inviting disaster . My hose is nowhere near a water supply when not in use,and this thread confirms what I have always thought what could happen , but from the sounds of this thread its common practice to leave the hose connected . IMO it would be good practice to have the hose no where near a water supply when not it use . I think there is a lesson to be learned here .
To the OP sorry that this had to happen, and hopefully you will get things straightened out.
