KCFDCapt's avatar
KCFDCapt
I'm In Deep DoDo
Long story short, the maintenance man in the campground did some work on the water faucets in my site. When he completed the work he had left the water valve off. When I returned from my run to the market, the wife commented the water was off. I went outside and saw that the quarter turn valve was in the off position and turned it on. I went to the office to see what was going on. I was there a few minutes and my wife arrived saying there was water flowing out from under the trailer and coming up in the toilet. I ran back to the trailer, pulled the black water drain and went to figure out what had happened.
The maintenance man had installed an anti-siphon connector on the black tank flush hose and had left the spigot turned on! Water, black water, was flowing from under the fifth wheel from front to back. All the insulation is saturated. They could not find a mobile RV repair person to come out to look at it. A handy man was called and he removed the bolts holding the bottom sheet from the belly, I raised the front of the unit, and the water was drained onto the ground. I brought the unit home the next morning. Now they have a haz-mat problem to deal with and I have a saturated fifth wheel sitting in my pasture.
My question is, can this be salvaged or is mold and bacteria from this a great problem? What about damage to the flooring from water underneath? The manager of the park said their insurance company would contact me next week. Any advice from those who have bad their black tank overflow into the insulated belly of their RV.
  • Maybe I'm looking at this all wrong. But I think it's the insurance company that has the problem. I would tell them to come pick it up.
  • What BO Plenty said! When I picked up my first 5th wheel, the walk thru guy was not the best communicator. When I went to connect it the first time, there was nothing marker, I connected my water hose to what I thought was the city water connection. Well it looked exactly like the connection I had in my class C? It wasn't, and the same thing happened, overflow! Called the dealer, they said, dump the black tank, remove the cover from underneath, replace the insulation, and after the covers, front and back, were dry put them back on! Now since it was new, as far as I knew the bath was still virgin. If I were you I would wash down your covers when they are off with some clorox, as well as the underside of your rig. Perhaps using a pressure washer to spray the misture on the underside with everythin removed would be a good idea, but be careful not to damage anything with the pressure washer. Let everything dry completly, let your nose be your guide then reassemble. You should be good to go! Good luck!!
  • It may not be as bad as you think.
    Keep us updated on your progress.
  • RoyB's avatar
    RoyB
    Explorer II
    What did the campground say about getting you all fixed up if this was their doings... They should have insurance for things like that happening..
    OOPS That twice this morning I didn't read the whole story... I see this question already answered...
    I'm gonna get a fresh pot of coffee going...
    Will be interesting to hear the outcome if it is totaled by the insurance company and campground has to buy a new one...
    Roy Ken
  • This has probably happened hundreds of times. Drop the covering on the belly of the trailer. Pull out the insulation and let it dry out. Replace the insulation and replace the covering. I wouldn't be overly concerned. People often lose track of what they're doing and overflow the tank while using the flusher. It's good the campground is taking responsibility for it.
    B.O.
  • Time to go shopping for another unit, I'd be willing to say that's an automatic write off.
