fj12ryder
May 23, 2013Explorer III
Individual axle weights advice and opinions.
I need opinions or actual experience, either will do.
I just weighed my axles individually using a Sherline scale rated to 5000 lbs. I placed the scale under the U-bolt closest to the wheel and raised the axle just enough to allow the wheel to turn. The amount that I raised the tire didn't seem to affect the readings, since they didn't increase before the tire was completely off the ground.
I don't know exactly what the difference would be if I measured right on the wheel since I'm about 6" from the centerline of the tire. I'm thinking the reading I'm getting now is a bit high because of that.
I've scaled my toyhauler just as it is now and the weight from the Cat scale was 10,640 lbs.
My individual axle readings are 2400 lbs., 2400 lbs., 2400 lbs., 2500 lbs., 2200 lbs., and 3100 lbs. for a total weight of 15,000 lbs.
That's a difference of over 4,000 lbs, which seems a bit off, to say the least. Does this seem reasonable to anyone, or is my methodology too far off to be accurate? If anyone has had their axles weighted independently did the combined weights agree with Cat scale weights?
Any opinions would certainly be welcome. TIA.
