navybankerExplorerApr 01, 2016Inside Step PadsWhat have some of you used to protect the carpeted steps inside your fifth wheel? These steps are the most used area and most likely to show wear and tear first. Thanks,
C_B_Explorer IIApr 01, 2016Originally rounded front wood tread w/ carpeted riser.Squared off tread, removed carpet and covered with linoleum that matches rest of floor.C.B.
Related ContentReplace insulation inside heater column.Carbon ceramic pads questionStepsBrake PadsSnap Pad Jack Pads
