Wadcutter
Jan 25, 2014Nomad
Check the cheapest fixes first. As others have said check the battery. Check the fluid level. If you've left the camper plugged in then the battery has been charging and it could draw down the water level. Clean the battery posts and cables. If you don't have a battery brush use sand paper and polish the posts and terminals to where the are shiny.
About Fifth Wheel Group
