Magman57's avatar
Magman57
Interior lighting dimming intermittently
I noticed my interior lights would dim and after a whole they would brighten antd the fan in the power supply box would come on. Something is not right. Ideas?
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
  • Old-Biscuit wrote:
    When on shore power converter supplies DC System and maintains battery voltage which should have much draw due to converter supplying DC System
    Disconnect POS Cable on battery (Or on DC Dist Panel)
    Measure Converter DC output...should be 13.2V DC Minimum.
    Any lower converter failing
    DC Output fluctuating/not steady....converter failing
    IF converter checks out...measure battery cells using hydrometer OR take battery ato any auto parts place and have it load tested
    Yup.
  • A good converter never 'turns off', just slows down the charge rate. Voltage should stay up even if the battery is getting old. His converter is bad. Battery is probably maimed also from being poorly charged by the dying converter. New converter first. That should fix the dimming, then new battery/s if it goes dead too quickly when unplugged.
  • When on shore power converter supplies DC System and maintains battery voltage which should have much draw due to converter supplying DC System
  • Funny thing; I thought it was classic signs of a bad battery. The converter would charge it up and the lights would come on bright. Then the converter would stop charging because the battery was fully charged but the battery could not HOLD the charge and the lights would dim. But what do I know?
  • Absolute classic sign of a dying converter - but get your battery checked first.
