In our last tt, I mounted our 500 watt inverter inside the main cabin,away from the batteries. In our new fiver I have a couple of options, inside the front compartment, or inside the pass thru compar...
I would put it in the front compartment, and higher than the batteries. That compartment is not well sealed at all. And if you're not seeing corrosion on things in the compartment now, you won't. It would also be a good reason to upgrade your batteries to AGM if budget permits.
