- 2oldmanExplorer IIThanks. Your inverter manual should tell you if it has a TS. Sounds like it does.
- RockinfigsExplorerIt'll run on all 3
Rockinfigs wrote:
Do those things run off shore/generator, or always the inverter?
the inverter runs all 3 TVs and 4 outles in the kitchen area - Any proper install will include a transfer switch and there will be no harm to running the generator, plugging in or running the inverter at the same time.
If it is an inverter/charger you may want it on to charge that battery. - RockinfigsExplorerwell Im assuming i have it cuz its a brand new unit.. 2020 attitude 3218mm it has the 1800 xantrex inverter..but either way im gonna turn off inverter before starting gen
- starcraft69Exploreruntil you find out if you have a automatic transfer i would turn it off.
remember to turn your converter on and off when going to inverter - RockinfigsExplorerthe inverter runs all 3 TVs and 4 outles in the kitchen area
- starcraft69Explorerwhat does the inverter run?
- RockinfigsExplorerHow do i know if i have a transfer switch? ok so il turn off the inverter before running the gen
- starcraft69ExplorerYes it does unless you have a transfer switch. you dont want to do that
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
