QFP
May 30, 2015Explorer
Inverter question
I have a 2013 voltage 3905 I would like to add a 5k inverter. I have 4 - 6volts 215 amphours each. They are set up in series/parallel. Has any one added an inverter and did you add a second transfer s...
QFP wrote:TVs about 300 watts, Fridge maybe 350 watts so 1000 watt inverter is all you need. I have and recommend Go Power sine wave.
I want to power as much as I can including TVs and refer. With 4 batteries i should have 400 amp.hrs. So you have 2 transfer switches?
