Eyetattoo wrote:
nayther wrote:
mustangglp wrote:
My 300 watt inverter will not run my cable box and hard drive for the DVr pluged in! It has to be hard wired to the battery's which are at the other end of the trailer from the TV.
Gary
Exactly what I did, runs TV/DVD or satellite box with NO interference. Had to run the 120 volt side to the TV outlet, then use a plug strip to power up the entertainment.
Are you using a Pure Sine or Modified Sine inverter?
Nope, just a cheap Harbor Freight inverter mounted next to the batteries and wired to an outlet next to the T.V.s.
