time2roll
May 13, 2016Nomad
RustyJC wrote:I will say it again. If you start with a fully charged battery it will work fine. The battery will retain plenty of power to operate the emergency brakes even after running the fridge etc. on a 18 hour drive.Charlie D. wrote:Amazing how many people don't remember that the PRIMARY purpose of the trailer battery(ies) is to operate the trailer brakes in case of breakaway. Providing the 12VDC for lights, furnace, fridge controls, etc. is just a fringe benefit. That's why it's so critical to keep the trailer battery(ies) charged and why I'd never even consider eliminating the +12VDC feed from the truck.smkettner wrote:If and ONLY if you know that your battery (ies) will not discharge below voltage needed to apply brakes to your rig if it should become detached. How is one to know if the batteries are being discharged below the safe level while driving without charging thus shortening their life?
If you start fully charged and always arrive at the destination with power to plug in then no go ahead and pull the fuse.
Rusty
If the battery cannot provide that power you have a defective battery, not a charging connection issue.
About Fifth Wheel Group
