newk
Jan 11, 2015Explorer
Unless you take special steps to keep your weight down, you're sure to be over your "maximum" cargo weight. Empty the 5er's pin is 2045. AT LEAST 20% of its carrying capacity of 2380 (480 lbs) will go onto your hitch (which itself will be ~200 lbs.). That would put your truck 150 lbs. over its capacity right there, then add people and whatnot and you'd be well overweight.
Depending on the weight of your family and how much weight you'll put into the 5th wheel, it probably wouldn't be a rolling hazard, but it wouldn't be ideal either.
It's not the length of your truck, just its limited carrying capacity. It's an older truck, and payload capacity back in 2001 wasn't much compared to today's trucks.
About Fifth Wheel Group
