Cummins12V98
Jan 12, 2015Explorer III
rhagfo wrote:Cummins12V98 wrote:
IMHO too much tail for your dog! Towing down the highway no problem. It's the unexpected that will get you.
Cummins12V98, Really you and I both tow(ed) than much with 2nd Gen Ram Cummins, yes it is 5' longer than my Copper Canyon, but almost exactly the same weights! The OP has 1,100# more GVWR than we did, and 746# more GRAWR than our 2500's. Well with the optional 265/75-16E with the Camper Package on mine that is what my rear axle should rate.
PAYLOAD!! To the OP, Payload equals GVWR minus TV loaded as ready to carry 5er. you will likely use up all your payload, and maybe a little more, I run right at 10,000# with our 5er in tow, zero issues. I still have lots of rear axle, and no issues with power.
It is your choice, but I tow the same weights, with a 2500.
I'm not talking weights. I said it would tow fine down the road. There is a point that the length comes into play. The 32.5 Avion I towed with a similar truck as yours was my personal limit on length. I had a close call with it going down a grade coming into Palm Springs when a gust of wind hit me. Not a good feeling! I felt that any more surface area and it may not have turned out so well!
About Fifth Wheel Group
