lynndiwagon
Jan 13, 2015Explorer
Russ, yes I did read the post. The OP is not only concerned about the length of the proposed rig but also seems to be concerned about the pin weight. I pull a 40' rig with a short bed Chevy D/A and was concerned about the pin weight also. After much research I determined that one of the main limiting factors of increased pin weight is the rating of the rear tires. To put my mind at ease I installed heavier duty tires on the TV. The length was never an issue, and I've pulled the 40' rig thousands of miles with all types of winds with no stability problems. Hope this helps.....
About Fifth Wheel Group
