FunWW
Jun 05, 2013Explorer
joebedford wrote:TugCE wrote:I totally agree with using the clutch instead of the brakes. However, I totally DISAGREE with leaving the engine off. If you do that, you run the risk of turning the engine backwards which could seriously hurt things.
When it comes time to back your bike out and down the ramp, leave the engine off and put the trans in First Gear. This way you can use the Clutch as a back break while going down the ramp.
Help me understand why you should NOT use your brakes backing out...:?
Maybe I will learn something here...
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 24, 2026
