Chuck___
Nov 06, 2016Explorer
Is it time to just give up the old truck?
You all have probably seen some of my postings in the past trying to figure out what my truck can safely tow. I would like to get a good quality used 5th wheel that is 28ft to 32ft range maximum length, about 5 to 10 years old. That way I just might be able to fit into most older state camp ground sites and yes, save a lot of money over buying a new RV. Thought of a Northwood (Arctic Fox) or possibly an Alpinlite. Thought that these types of units would last for 10 years or so into my retirement and I don't want to purchase a low-low quality unit that will fall part in my hands. The big problem I am finding out is my 1999 Dodge 2500 diesel seems to not be able to handle the weight safely. Also people on the forum say it really is not worth spending the money trying to build up the truck for towing. The truck is in good shape and I don't want to have to purchase a new/newer truck if there is no need to.
1. Should I just give up the old 99 Dodge and get a 350 one ton? Purchase a Diesel 350 dually or a 350 single rear tire one ton?
3. Try to find a much lighter 5th wheel?
4. What brands of smaller 5th wheels would you recommend if I have to keep the 1999 truck?
Please see the information below in order to give me some advice.
I have been trying to know exactly what my truck can safely tow and what is the maximum 5th wheel ight I can "safety handle".
My neighbor who is a professional truck drive and his mechanic has told me that to just drive senablity, within the speed limit, weather conditions and so on. The mechanic told me he has a truck like mine and has tow up to 18,000 lbs trailors. The only problem he had is with the power up hills. I get so many different figures and stories form charts specifation sheet, VIN number specs and people I don't know what and who to beleive.
Please tell me if I am calculating the weights right and any other advice.
1999 Dodge Cub/Quad cab 2-wheel drive SLT Automatic Turbo diesel with 160,000 miles:
My tires at 10 ply 17 inch, rated for 3,000 for each tire.
VIN #: 1B7KC2360XJ636854. I could reinstall the 16" tires and rims.
On the drivers door: GVWR= 8,800
Front GAWR= 4,410
Rear GAWR= 6,084
Weight at Scale:Front Axle= 3,880
Rear Axle= 2,780
Total weight= 6,540
Pin weight calculation? 2 people weight: 350 lbs
Hitch weight: 250 lbs.
Food and extra inside truck: 50 lbs.
Total : 650 lbs.
Weighted truck:6,540 plus extra weight Total: 6,540+650= 7,190 lbs. Add the extra 650 lbs for true life calculations.
Pin Weight: GVWR 8,800-7,190= 1,610 lbs.
On page 148 of my owner's manual: Axle Ratio: 3.55
Have to use the Regular Cab 2-wheel drive rating. Owner's manual does not show Club/Quad Cab 2-wheel drive 2500 with 3.55 axle ratio
Auto Tran: GCWR= 16,000 and Max Trailer Wt.10,200.
So, using cancellations: Maximum 5th wheel weight GCWR=16,000- Truck weight of 7,190 lbs = 8,810 lbs. 5th wheel weight. Safety factor of 20% = 7,048 for a 5th wheel. Does that mean we can't put any weight inside the trailer?
I don't know if I am reading to manual right of my calculations are right.
I been told if I put a couple of thousand dollors into the truck it be will worth it; thinking up to $5,000 or so. The truck is still good shape. Should I install air bags, extra leaf springs, exhaust brake, bigger tires and disc brakes for the rear end? Is it worth it for a 1999 3/4 ton truck with only 160,000 miles.
I had the transmission rebuilt; asking to have it built extra heavy duty with shift kit and cooler. Also had ball jouints and bearing done for the new front end, new rotters, drums and brakes this year.
I hate to shell out $65,000 to $75,000 or more of a new/newer 350 diesel 4 door if not needed.
Been looking at 2005 to 2008 Alpenlite and or used Arctic Fox (Northwood) 5th wheels. Hoping the weight wouldn't be too much.
Help, I need it. Going crazy!
Charles in Salem, Oregon
Front GAWR= 4,410
Rear GAWR= 6,084
Rear Axle= 2,780
Total weight= 6,540
Total : 650 lbs.
