rmoore0852
May 23, 2016Explorer
Ok, update and looking for advise. Pumped out 13 gallons of fuel, so it still had almost a half a tank while the generator was acting up. Dropped the tank. Pulled the pickup tube, expecting corroded metal. Well, what a surprise when it is plastic. There is an aluminum elbow that has a barb on the end with a plastic pickup tube that goes almost to the bottom of the tank, so now I know that I have to be sucking air. The plastic tube is not clamped at all to the barb. It is pressed on snug, but I can spin it with my hands and can pull it all the way off with some force. I can't find any obvious leaks, and I know that the fuel line is good, since it ran fine for two hours before quitting. It has to be related to the fuel level in the tank. Two options, what are your thoughts?
1. Seal the plastic to the metal with some JB weld and put it back together. This seems like the safest bet, since it uses the factory plastic and aluminum fittings.
2. Build a new pickup tube with brass fittings and copper tubing, all soldered together.
I sure hope this is the problem. Next day off I will run the generator from a gas can that I put the fuel line from the tank into. This will check the entire fuel system except for the tank. I don't see how I could have a bad fuel line, since it ran for 2 hours before acting up.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
