Bedlam
May 24, 2016Moderator
rmoore0852 wrote:Bedlam wrote:
Could your fuel pump be going out and it is too weak to lift fuel once the tank runs down?
I have definitely considered that, but when running from the gas container, it was a quart container on the ground. A good 18-20 inches lower than my fuel cell. I would think that this additional lifting distance would have caused more problems. I don't know how to strain the pump any more than that. It ran perfectly for an hour before hooking back up to the tank, where it died within 5 minutes.
It sounds like the pump is fine. I would lean toward a leaking pickup fitting or line like others have posted.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
