jayhardy wrote:
I have a 2014 Montana that came with a project Waterpump. I can't get it to work. I filled the water tank, turned on all the faucets, and then turned on the pump. I can hear it but no water flowing after 5~7 minutes. Any thoughts and where I'm doing wrong.
I have an appointment for my 2014 Montana next month at our dealer for same water pump problem.
If mine is disconnected from the fresh water tank line and instead pumped out of a 5 gallon bucket of water it works great. Therefore, the water line that goes from my fresh water tank into the fresh water pump is either not connected right at the tank or could have a split/hole in it along the way.
Anyhow, that line is inside the underbelly and travels back to the rear of the unit where the fresh water tank is located. I am still under warranty so I am going to let them drop the underbelly and fix this issue.
