jayhardy's avatar
jayhardy
Issues with project waterpump
I have a 2014 Montana that came with a project Waterpump. I can't get it to work. I filled the water tank, turned on all the faucets, and then turned on the pump. I can hear it but no water flowing after 5~7 minutes. Any thoughts and where I'm doing wrong.
  • jayhardy wrote:
    or is it the location outside with all the water hookups referred to as the closet
    He said "closest" no closet.:)
  • or is it the location outside with all the water hookups referred to as the closet
  • When u say closet faucet are you implying the lines installed for possible washer and dryer
  • Close ALL the faucets
    Then with pump ON open the hot side of closest faucet until water flows.
    This allows pump to prime.....fill water heater tank and pump thru hot lines.
    Then you can purge air from cold side and then go to other faucets/shower/toilet etc. one at a time
  • If you have an antifreeze siphon line check to make sure the valve isn't open to the siphon side.
