drwwicks's avatar
drwwicks
Jacking and tire replacement
Am getting a 5th wheel, 2012 PT Crusader, this week and will be doing a few repairs and maintenance adjustments. Tires are suspect. While they are not that old, their brand and origin leaves a lot to be desired. 3 are 235-80-16 Soltera. 1 is a Noble 235-85-16. Date codes on Soltera mid 2015 and Noble mid 2016. Age and tread not an issue, quality is. Unknown Chinese ****. I say unknown because on a couple of forums I have asked is anyone has info on these brands with no responses except the generic, "china bombs" etc. That I know I want specific info. Iv'e also googled them with little info except they are for sale.
That said I am planning to replace with GY Endurance of the 80 aspect ratio, LRE. I am going with ST so please avoid the ST vs LT discussion. Sam's has them for good price and I plan to haul them in to install.
Jacking:??? have a 20T bottle jack, 4 automotive type jack stands, and a lot of wood blocks, 2x6, 6x6, etc. Been a while since I jacked a trailer up so I'm asking about best and safest method. I would like to take all 4 tires on one trip since the Sam's isn't next door. I suppose that raising one side, lowering securely on blocks, removing wheels, and repeat on the other side. Other than chocking the tires opposite the first set being removed, don't know any other precautions. Will be on a level concrete pad.
What is the best jacking point and then best supporting location? Frame next to axle, under spring shackles, ??? Remember that where it's jacked can't be used for supporting because only one bottle jack capable of lifting. Any precautions on the front landing gear?
Only other issue is the trailer has no spare so I'm planning an appropriate 16" white steel wheel and use the best of the existing Soltera tires for a spare. This 5th wheel will not be making long trips but I want good and safe rubber on it. Thanks for the assistance.
Adding; While the wheels are off, I'll inspect and repack the bearings, inspect brakes and generally clean everything up. My previous PDI found a broken wire to the left rear brake right where it goes into the back of the hub. That will be repaired also. Couldn't really tell when I was on the creeper under it how the wire goes in. Single white wire. Any other recommended inspections or adjustments while I'm down there?
