Jerry_B's avatar
Jerry_B
Jacking for a flat tire?
I made a heavy duty ramp to lift a flat tire high enough to remove the wheel. Turns out, the ramp will not fit between the rear wheel and rear stabilizing jacks. My bottle jack is too tall fit under the axle of the flat tire. How do you jack your RV to change a flat? Thanks
  • I don't know as I have never had to do it .
    But , my guess is the standard jack packed with my duramax under the rear seat will fit under the axle .
    If not pull forward over a 2x6 block or two and the jack will fit then .
