sayoung
Oct 08, 2019Explorer
oldmanriver809 wrote:
Hi everyone I hope someone can help me out with my installation of the replacement Fasco ac motor I just purchased. My original motor had bad bearings and froze up. I purchased the exact motor only newer since the original is from 2008. The original has two brown wires that plug into the capacitor. I had to mark one with a marker before I removed it for replacement. My problem is that the replacement has two brown wires too but one is brown and white and the other is brown and black so I have no idea which one plugs into which capacitor.. I can’t figure out how to post the wiring diagram that is on the motors or else I would. Thank you all in advance.
Just wire the brown/white as tho it's all brown. It is marked that way so it can be wired as a 3 wire setup . I am not going to confuse you on how to do that. I'm retired AC guy.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
