BB_TX wrote:
breeno wrote:
. I can't for the life of me figure out how to do the back arms with how my 5er is laid out, but just having the front done was a pretty impressive gain in stability.
At the rear, I (from reading about others doing it) bought a piece of 2"x2" square tubing long enough to reach from the outside flange of the I beam on one side to the outside flange of the I beam on the other side. Cut each end of the sq tube at a 45 degree angle and drilled two holes at each end. Drilled matching holes in the I beam flanges and bolted the tube across the rear to the I beams on each side. That made it easy to attach the JTs on the rear.
Some used 2"x3" tubing to give a wider surface to attach to the I beams. But I already had some 2"x2" and it worked fine.
And you are right, they do make a lot of difference.
Very clever idea. I'll call JT and get their input but this seems like a pretty slick option. Thanks!
