3ares's avatar
3ares
juncion box wiring in pinbox fifthwheel
The wiring in the juncion box wiring in pin box has come loose. does anyone know the correct way to connect the wires?
  • Chris Bryant wrote:
    Be aware that this diagram is for cargo and boat trailers, and the RV color code is different.
    That is correct....I posted wrong info. That one is for utility trailers etc.
    (How come you didn't post correct color codes :H )
    This chart shows the various wiring schemes used.....utility/RV/Commercial
  • rhagfo's avatar
    rhagfo
    Explorer III
    Did they just come loose, or did the umbilical get pulled out.
    If the umbilical got yanked out hopefully all the other wires are still connected together so you only need to figure out where each of the 7 wires land.
    If multiple connections in the box came loose that could be a challenge.
  • Be aware that this diagram is for cargo and boat trailers, and the RV color code is different.
  • Old-Biscuit, seeing that you have a HH would you know what amps the fuses are to each of the wires in the diagram? The diagram will be very helpful to keep in the rig..thanks
