Tax_Man
Dec 08, 2016Explorer
I talked to the folks at HWH once. They said that the leveling jacks are not designed to hold a vehicle off the ground. The system may be used to lift one wheel off the ground to change it.
Use the 6 point system to level and place blocks at several points to hold the frame. Jack up the axles and remove the tires. Put blocks under the axles also.
Just my two cents...
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
