laknox
Dec 13, 2016Nomad
aruba5er wrote:
blocks would hold it up forever but make sure you don't put them sideways. They are not very strong used on the side. Web verticle, like you would put morter on. I'd start by putting down a piece of 2x10 or 12,to provide a larger surface, then build up the height with block and finish off with whatever 1x treated lumber needed to make level. then lower the fiver down to the crib you've made. I'd just cover the wheels with a good cover. Forget about moving it. Tires are going to rot regardless, later rather than sooner by covering them.
Why use blocks? Harbor Freight has inexpensive screw jacks. Gives you infinite adjustment. 4 or 5 on each side... They also stack for storage and are lighter than blocks or cribbing.
Lyle
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
