dougford
May 14, 2014Explorer
You do realize that unless you're hooked to shore power or running the generator, the outlets in the toyhauler have no power? The batteries on the tongue only run the 12-volt items in the camper, and not the 120-volt outlets/items. Two separate circuits.
I'm surprised you have issues after only a month. I never even unhook the batteris, and go for more than a month at times on some of the bikes/ATVs. I try to start them at least once a month, but sometimes it goes longer.
Finally, the solar charger on the tongue bateries will keep them charged up. But, I just unhook (actually I installed a three-way switch) those. The camper, even with everything off, will still draw some 12-volt power, and drain those in a month.
About Fifth Wheel Group
