JEBar wrote:
when a Jack antenna is used to replace and OEM bat wing, the signal booster that comes with the Jack should not be used .... the OEM signal booster (the one controlled by pushing the small black button on the plate where the coax is connected) should be used .... if the OEM booster is turned off, the Jack will not perform well .... when the coax is unscrewed from the bat wing, all that is required to connect it to a Jack antenna is to screw it onto the fitting provided
Jim
that is not an amplifier, it's a power supply. You cannot simply remove the amplifier from either the Jack or the Batwing, and there is no reason one cannot use the Batwing power supply on the Jack. But in the end the flat best performing antenna IS the batwing.
