david_gower
May 09, 2016Explorer
The tank is a 86 or so gallon tank and when it was full the water was coming out of the vent tubes back by the axles. I don't have a tank drain. To drain the tank I have to pump the water out and switch a valve from "normal flow" to "drain tank" which dumps it out right below the water control panel which is up front behind the hitch. The tank is in the back of the trailer.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
