Almot's avatar
Almot
Explorer III
Oct 08, 2017
Larger suction pipe to pump - better?
All inside tubes, inlets on the pump, and suction tube from fresh tank are 1/2". 3GPM pump, 40 PSI on the push side, self-priming up to 10ft (I think).
Now, imagine fresh tank 6ft away, sitting on the ground on seasonal camp (no city water there). If I run 3/4" suction pipe to the pump, leaving the output side unchanged 1/2" - will it be better, worse, or the same? Plumbing theory suggests suction/input 1 size bigger than output, but I have a feeling that it will not matter much on this short distance.
There is 0.5 micron sediment filter before the pump, with 3/4" outlets and 1/2" adapters, so I can have input tube either 1/2 or 3/4. Filters have been known to prefer larger input, too.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
