Good, Bad, or not worth it? we have a 29'er...DW is wondering if a King Pin stabilizer is a good thing or not....advantages, disadvantages? Are some better than others? Comments appreciated....
Put all your gear down, then go push on the side of the 5'er at the back. You can make the 5'er wiggle. Putting either a tripod or JT type diagonal stabilizers on will help. Even putting just something on the front won't take out all the wiggle, as the tires flex up and down and sideways. I installed a diagonal stabilizer on the rear and that IMO is the key. ON blacktop I can get it really solid, dirt/gravel not so.
