We have a 16 2500 and have been very pleased with it. Only had a couple of items for warranty before the 24 month warranty ran out. LED light strip in awning and the wood around refrigerator was moisture damaged. Turns out the damage was because the refrigerator vent was stopped up. We had a 13 Montana before that and I feel that it is as well built as the Montana was. I had just upgraded to Sailun G rated tires on the Montana and had those moved to the KZ when we traded. Depending on the weight, I would recommend going to G rated tires. Also, ours has the adjustable height suspension like a previous Jayco had on it. Mine is as high as it will go and I have about 7" clearance towing level.
