spud1957
Oct 23, 2014Explorer
Shilohking wrote:
My 3-year old Cougar 5th wheel has two small courtesy lights over the landing gear. I never use them. I parked the rig on a storage lot for the winter three days ago, checked that everything was secure, and turned the battery disconnect switch (in a compartment) to kill all power to the battery.
Got a call last night from the storage owner who said the courtesy lights were ON. They can be turned on/off by an external simple switch, but the switch would not shut them off.
I opened the compartment to check the battery cutoff. It was in the correct position to cut power from the battery. Curiously, the toggle switch to raise or lower the landing gear also was receiving power and was working.
I had to disconnect the battery to get the lights out.
Does anyone have an idea what's happening, or are Halloween gremlins taking over my Cougar?
Jerry
The only way those lights get 12v is thru the switch. That's the first thing I would take apart and look at.
About Fifth Wheel Group
