Greyhound_RBExplorerFeb 24, 2021Landing Gear LubricationI have a 2012 Keystone Cougar 323 MKS. The landing gear motor seems to be straining a good bit under load. Is there any good info on lubing the shaft/nut. Thank you.
Dave_H_MExplorer IIFeb 25, 2021as MLF says. Mine are located on the back side where they are hard to see much less grease. :h
Related ContentLanding gear lubricationLubricating the landing gearGood lubricant for landing gearReplaced landing gears and switch. Switch extends both wayslanding gear issue
