ivbinconned wrote:
I can see no zirk or feel one where I can not see. Is pouring oil in from the top going to lube the entire shaft?
Another desire I mentioned was to get rid of the cross (head banger) member. Two motors would do this. This would make building a shelving system and access to-it very nice.
I am sorry ,I mislead you, no you don't have any Zerks, I don't either , on the one side, I replaced the drive side ( Don't ask :( ) and it does have the double zerk. The old side does have a small hole where a zerk would be ,but no , ,no zerk.
I mentioned I pulled off that side ,and greased it partially torn apart. Yes pouring into the top will get it, it will run thru the nut that the worm gear runs thru, and should get the worm gear also. I would put as thick as I could get that will pour. I am going to do the same, and just put something under that side to catch what runs thru. The other side I will grease the zerks .
