Campinfan's avatar
Campinfan
Explorer III
Jun 29, 2015
Langing Gear Issue
I went to hook up today and when I went to use the switch to raise and lower my landing gear it did not work. No hum, nothing. I go the remote that came with my trailer and that worked which allowed me to raise and lower the legs. To me, it sounds like the switch is bad. I took off the switch and there are 8 wires going to 6 terminals...two of them have tow wires linked together. Anyone know how I can check my switch. I tried making a jumper out of a piece of wire but it did not work. Any ideas, suggestions, etc? Thanks
  • check the self resetting breaker too. I just had mine go out last fall. Not sure really how they're wired and if some are different but I noticed mine though my lights too when on the batteries. My lights would flash off.
  • That switch cost me $7.96 at a local rv repair shop. Mine quit in the down mode only. Easy to replace too.
  • Center is 12+/- the switch reverses polarity so a VOM should show you easily enough. There is a lot of amps through it so failure is pretty common.
