Giggitygoo's avatar
Giggitygoo
LCI Auto Level troubles- 6 pt electric
I curious if anyone else is having trouble with their auto level system. Mine is on a 2013 Voltage 3905. I brought mine to dealer after the first use becuase the right rear jack never came down or the middle two jacks either. They said it was fixed, I took it back out again and the front and rear jacks lifted the front and rear axle off the ground and the middle jacks never came down (it was never level- it read out of stroke). I was on level ground and had 5" word of pads under rear jacks. I wonder if the gyros on not sequenced or operating properly.
Thanks for any insight.
  • The front and rear jacks level the trailer. The middle jacks only come down to act as stabilizers when the others have it level. The middle and rear jacks only have 4" of stroke (if they were longer. They would stick up through the floor).
    When you park the trailer, cycle through the screens until it tells you exactly how far out of level you are. You need to get the trailer to within 1 degree of level side to side first. More than that and the rear jacks won't have enough stroke to get it level. Id you are on a soft surface, dig small holes for each tire and park with the tires in those holes. On a hard surface, drive onto blocks to raise the low side. Once that is done, drop the front landing gear and unhook. Then raise or lower the front until the trailer is within 1 degree of level again. Then put blocks under the rear and middle jacks. The. You are then ready to push the auto level button.
    You have to get it close the old fashioned way, it then does the fine leveling and stabilizes the trailer. Once you do it right a couple times, you'll get the hang of it and you'll be set up drinking a beer 5 minutes after pulling in.
  • Giggitygoo wrote:
    gravessat wrote:
    I had the same problem, I had to manually calibrate it, you dealer should be able to give you the instructions.
    However every now and again the center jacks will not come down all the way and I have to do another autolevel.
    Do your center jacks come down last when they do work?
    Mine do. That thing hasn't broke yet but for now I think it is the Cats MEYOW!
    The dealer has recalibarated it twice for me, I am still getting the same result. I am bringing plenty of wood for pads where needed, not sure what else to do.
  • I just got off the phone with LCI and they told me that I need a group 27 battery to fix the problem since the motor is pulling too many amps (spikes). They said that 90% of problems like this are from lack of available amps. I currently have 2 Interstate deep cycles in parrallel.
    What kind of battery do you run (those who have a functioning system)?
  • Think of the auto level as more of an auto stabilizing system. You need to get the trailer pretty level before using the system. If there are any low spots build them up with pads or wood under the jacks and if necessary under the tires.
    Think of the "out of stroke" message from the system as one of the jacks (or more) can't extend far enough to do its job of getting that portion of the trailer level. Just like if you had traditional hand crank jacks and one of them extends down all the way yet doesn't touch the ground.
    When the system goes into the out of stroke mode, it stops all jacks, so if your middle jacks are not coming down, it tells me that on one of the four corners the jack has extended as far as it can go and halted the system.
    Using a traditional level on the floor or counter you can tell which way the trailer needs to do, retract all the legs (except the front two) build up under the jack that has extended to its full stroke, then try again.
    We mainly dry camp or boondock, so I never have a very level surface, I carry blocks to put under jacks. Once you get the hang of how the system works, you will LOVE it.
    I hope this helps?
  • I had the same problem, I had to manually calibrate it, you dealer should be able to give you the instructions.
