Likes_to_tow
Sep 04, 2013Nomad
SledHedEd wrote:
Sorry. To clarify, it's not leaking between the frame and the body of the camper. It's the seal between the glass and the frame. I watch the water drip down the glass and go right by the seal then see it start dripping inside from under the inside frame. Thanks for the responses so far.
I had this exact problem. I fixed it by taking black 100% silicone purchased at Lowes Home Center, running a small bead around the window right at the joint between the glass and rubber seal, and then taking my finger and lightly running all the way around the seal and smoothing it out. This creates a really great seal. You can also run a slight bead around where the rubber seal meets the metal frame and also run your finger around to smooth it out. Be careful not to use too much. By using black silicone it looks a great deal like the original rubber and unless you know this has been done and get up really close you can't see it.
I did this right after purchaing my 06 fifthwheel used in 09 and here we are in 5 seasons of use and I have absolutely no leakage what so ever. My window leaked so bad that it filled up the aluminum track area on the inside and then begin to run down the wall!! I had been considering purchasing a new rubber seal and trying to install it before remembering that I had sealed the winshield on a boat several years ago and also had repaired the rear window glass leak on an automobile. For some reason silicone sticks to glass really well.
Don't waste time and money trying to replace a difficult seal....
About Fifth Wheel Group
