Frank55
Jun 28, 2019Explorer
Leaky waterhose
I keep having a waterleak on the hose coming into the trailer. I have put a new washer, used teflon tape and have tightened it up as much as I can an it still leaks! Any suggestions.
belairbrian wrote:Yeah, it sounds pretty obvious that you can't leave it under pressure all the time. Seems to be self-explanatory to me, but maybe I'm missing something.rhagfo wrote:
Quality hose, while the current white hose is still sealing fine, when it starts getting leaky it will be replaced with a ZeroG hose.
I looked at the Zero G but then I saw that they are "Not recommended to be under constant pressure"
What does that mean? Do I have to turn off the hose at the campground valve when not using water?
