DavinD wrote:
The terms used in trailers are.
Full Profile - these are the ones where the roof is straight across giving you the maximum height in the back of the trailers. Usually associated with high-end and expensive (usually)
Mid Profile - Just like it sounds somewhere in the middle
Low Profile - These are the ones with the lowest ceiling. Usually cheaper brands.
That being said, this isn't usually listed in the marketing material, but the salesperson usually knows.
^^^This. The higher living area in the rear allows for taller slides. If I'm understanding your modifications, I don't think that will work.
Going from zero experience with a RV to living in one full time will be a challenge.
Your husband sounds like he really doesn't want to do this and you really do. I'm not a marriage counselor, but I think y'all need to kick around how to resolve that. Getting a RV is stressful enough without one of you being dragged kicking and screaming into the deal.
