- golf_bearsExplorerHas anyone tried these levelers out on wet grass? Do they slip away as you try to climb up on them? How long are they from end to end?
Hope someone answers the question about space needed between tires soon. - Dave_H_MExplorer IIAnderson looks cool. I would order them today but wonder about the space needed between the wheels. I got a smidge over one inch between the 16 inch wheels.
What do you Anderson folks think? - cpaulsenExplorer II
martipr wrote:
ScottG wrote:
I discovered Anderson levelers right there on RV.net.
No need to carry lumber and no trial and error. Just pull up until the level on the front of the rig shows it's good.
I no longer carry any boards for leveling, just some small pieces of 2X6 to put under the stab jacks.
Absolutely, I bought two thinking they would be better than boards or Lynx but after a couple of trips I think I would quit RVing if I had to give them up. They take all the hassle out of leveling. They are fairly expensive (around $45.00 each) but are worth 3 times as much, and I am one of the stingiest people you would ever meet.
Got some of these also....40 bucks apiece but so easy to use. - DuckExplorerAnother Lynx here.
Don - azjeffhExplorer
whiteeye42 wrote:
The anderson levelers are nice but how do they work when the ground is soft and or in gravel
And what about the tire spacing needed to get one between the tires? - whiteeye42ExplorerThe anderson levelers are nice but how do they work when the ground is soft and or in gravel
- The cheep yellow lego blocks work for me. I think I have 17 out of 20 remaining.
- MTPockets1ExplorerLynx - light, easy to rinse/clean, easy to use/store.
- Cummins12V98Explorer III
azjeffh wrote:
Cummins12V98 wrote:
I carry 1/4" thru 1 1/8" plywood in 10"X10" squares. I like to sit perfectly level!
You do realize you could be 1/16" to 3/16" off level and not know it :B
If I have to I scratch she surface to maintain perfection!
Actually by adding 1/4" to one wheel it only changes the height by 1/8". ;) - azjeffhExplorer
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
