Ljm352 wrote:
I do have stabilizers but the front stabilizers are not pinned at the same level. One is standing taller than the other, (but only about 3 notches) because of the slant I'm on. I did not have boards for under the tires. In the back I jacked it up and put a couple blocks under it to basically level it out. Will this be okay for a couple days since I am away from it?
I agree with your neighbor. IMO, you could damage the frame, leveling the way you did. You need to level side to side, while still hooked to truck. The only way is to put something under the low side tires.
You need to borrow some wood from a neighbor, get your own wood, whatever it takes, but level side to side, lower landing gear, unhook, level front to rear, and put stabilizers down.
Jerry
