Ljm352 wrote:
I do have stabilizers but the front stabilizers are not pinned at the same level. One is standing taller than the other, (but only about 3 notches) because of the slant I'm on. I did not have boards for under the tires. In the back I jacked it up and put a couple blocks under it to basically level it out. Will this be okay for a couple days since I am away from it?
Your doing it wrong that is for sure. If parked side hill, you level a trailer side-to-side by the axles/tires, not by lifting/jacking the frame.
