time2roll
Nov 10, 2017Nomad
Check the 12v system voltage with a meter. 13.6 volts?
Check the battery for excessive gassing and heat. Also check the water level.
Then disconnect the battery as the PD converter should run the RV just fine with no battery. What is the voltage now in the fuse panel?
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 11, 2026
