gat75
Nov 10, 2017Explorer
time2roll wrote:
Check the 12v system voltage with a meter. 13.6 volts?
Check the battery for excessive gassing and heat. Also check the water level.
Then disconnect the battery as the PD converter should run the RV just fine with no battery. What is the voltage now in the fuse panel?
Thanks for the tips, I plan to troubleshoot it tomorrow morning.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
