ScottG
Nov 10, 2017Nomad
Removing the battery should cause it to stay in one mode. So that's a good test. If it's rhythmically going from bright to dim it's probably the converter.
It may also be that your PI is just going into another charge or desulfate mode. You should monitor the voltage to see what's it's doing. If it's switching between 14.4, 13.6 and 13.2V's, it's doing its job. When the converter drops the voltage to the next stage, the battery voltage itself slowly drops and so do the lights.
It also goes into the desulfate stage something like every 20 hours and acts kinda strange.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
