Sam_Spade
Nov 11, 2017Explorer
ScottG wrote:
You should monitor the voltage to see what's it's doing. If it's switching between 14.4, 13.6 and 13.2V's, it's doing its job.
This is most likely the cause.
Changing out the bulbs to LED probably would make it less noticeable......and less frequent.
Probably nothing to actually worry about but it could be a sign that your batteries are getting weak or a connection needs tightening.
I have found those little plug-in battery voltage monitors to be an invaluable tool.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
