wvcampers
Nov 14, 2017Explorer
I had the same thing happening with my Cardinal. I replaced the converter and the problem was cured. That was about 3 year ago, no problems since.
When you check the converter output make sure that it is under load.
When you change the converter, get one that has a seperate battery charger that will not overcharge the battery.
If you are not a member of the Cardinal RV Club, you should join. There are lots of Cardinal/Blue Ridge owners on the site that are very knowledgeable about these rigs and are eager to help. The best part is it is free!
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
