time2roll
Nov 14, 2017Nomad
gat75 wrote:Disconnect the battery and let it rest a day or two and see if it holds 12.65 volts. The PD converter will run the RV just fine with no battery.
Well, had time today to begin troubleshooting. With battery disconnected, I had exactly 13.6V coming out of the Progressive Dynamic converter, (per my fluke tester).
My interstate battery tested at 13.4V
Guess I must have a short somewhere...
If the trouble persists with no battery continue to monitor converter voltage and you might have a bad connection that is causing resistance. First check would be the ground bus and the main connection to the frame.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
